Hi. I like the idea of the New Arlo Ultra Camera System but I have a few questions that I hope someone can answer please.
My current set-up consists of Two Arlo Pro 2 Cameras plus Two Arlo Secutiy Lights. They are positioned at the front door and on the driveway.
If I purchase the New Arlo Ultra Two Camera System - Will my Two Arlo Security Lights still Sync as they do now. Can I set-up the New System to incorporate my existing Two Arlo Security Lights?
Second question - Do the Arlo Ultra Cameras fit the existing Outdoor Security Mounts?
Many Thanks!!
Blacky17557,
Yes, your existing Arlo Security Lights will work with the new Ultra system.
The Ultra cameras have the same standard thread that the Pro/Pro2 and original wire-free cameras had. They are compatible with the Arlo outdoor security mount (VMA1000)
Blacky17557,
I added an Ultra camera and hub to an existing Pro 2 system with two lights. I kept the old Pro 2 hub and just added the Ultra hub and camera to the existing setup.
The Ultras will work with existing threaded mounts.
Hi and Thanks for your quick reply James - very much appreciated.
You have answered the questions that I needed answered!! Thank You!!
Accessing Local Storage
