Green frames on Arlo Ultra
  • 8 Replies
  • 4803 Views
Tim_BR
Since a few days ago, I started to experience these green frames when I view the live cameras through the App. Already restarted the hub, re-synced, etc, nothing works. Internet speed is good as usual, nothing different in the position os the cameras. Does anyone have a clue how to solve it?
8 REPLIES 8
Tim_BR,
It sounds like you could be experiencing an interference issue. What is the signal strength for the camera having the problem? Does it always occur or is it intermittent? Can you provide a screenshot?
Tim_BR
Hi James,
I've attached a printscreen in my previous post...
It is happening most of the time. Sinal strenght is at two or three bars, just like they used to be before. I've tested the wifi speed with SpeedTest and nothing different as well.
Rgds
Tim_BR,
Sorry, I missed the screenshot. Do you see this corruption only on live streams or does this happen in recorded content as well?
Do you have more than one camera that is behaving this way?
Tim_BR
I see it in more than one camera, only in live streams, since I live in Brazil and I can't record the videos (I bought a memory card, but it consumes too much battery and since the energy cables aren't available for sale yet, I have disabled that feature - but that is another issue).
Tim_BR,
This symptom usually is a sign of some sort of interference. To further isolate, try bringing the camera close to your base station (within a few feet just as a test) and try again to see if you experience the same behavior.
Tim_BR
I tried, but curiously the one that is the farthest away from the base is the only unit that doesn't show those green lines. I've already made up my mind, these Ultra Expensive outdoor wireless cameras will have to be used only indoor, with energy cables (when available), and I'll install an old-fashioned camera set with DRV, cables, and so on so I can rely on the system.
Tim_BR
Example attached (the one above is very close to the hub).
Tim_BR,
Is the green frame issue you're experiencing only happening when the cameras are placed outdoors? If you bring them indoors, do you experience this behavior?
  • 8 Replies
  • 4804 Views
