Hello,
As I noticed the adapter for Ultra Hub does not support higher then 120. I have read on forum for some
it does work. Seems like its not a big deal getting a Euro Adapter thats 12V-1.5A output but which barrel connector is it ? M-type or C-type ?
Don't know what M or C type is in the US, but its a coaxial plug...
I've used 5.5mm x 2.1mm coaxial plugs and they work for my external powering ( you also may get away with a 5mm dia )
*** center positive***
@JohnPL1 wrote:
M-type or C-type ?
Are you talking about the mains connection here?
If so, the US adapter isn't grounded, so type C will be fine. But it should work just as well with Type M, as long as the DC output voltage, current, and polarity are correct.
@JohnPL1 wrote:
Hello,
If you are talking ab out the mains adapters that come with Arlo kit, it says 120 volts but works happily at 240 volts. I have several on the go at the moment.
I have tried half a dozen different adapters for cameras, hubs and what have you. Have yet to experience a flash bang wallop.
As to replacements, just look for the right volts, +/- polarity, amps and tip size.
Cameras, of course, can run with most USB power supplies so long as they deliver enough juice.
Just another user
Accessing Local Storage
