Can you access SD through app
  • 1114 Views
CarrieF
Hi, I have found some posts about how there was suppose to be access to the recordings on sd card at the end of last year. Has this happened? We had a free year subscription and now we can't access any videos on phone unless we sign up to a $15 or $25 per month plan. Seems a little excessive considering a lot of the other cameras have 7 day cloud storage. Wish I had know it was one of the only ones that don't before I bought them.
michaelkenward
Sensei Sensei
Sensei
That is for the Pro 2 and older cameras.
Doesn't it say something about this on the box? Very naughty if it doesn't.
$25? Where are you?
Arlo subscription plans and cloud recording
Starts at $9.99.
What is Direct Storage Access and how do I use it?
Just another user
Local recording access via the latest apps has been available for some time now. If you have the appropriate device inserted into your hub/base and it's enabled you can view the local recordings via the app. I don't know how it works without a subscription but for me I get a button at the top of the library that, when clicked, gives me the choice of either cloud or local recordings. I suspect you would see that without a subscription but can only choose local recordings.
The business model changed with the release of the Ultra over a year ago, requiring subscriptions. It's been well-advertised and documented since then. Only the older cameras, Pro 2 and below, have the free 7 day plan for up to 5 cameras.
CarrieF
Thank you for replies, I will try tomorrow when I pick up sd card. Free trial has only just run out so I didn't have one.
  • 1115 Views
