How can I enable my partner to access local storage? My partner has access to the cameras, and to the cloud, but not to the local storage.
The only way for your partner to access the SD library is with your access. It is limited to you so they would need to use your login.
Thank you for your reply. Is there any hope of product enhancement on this issue?
It's been 15 months since I purchased 7 ultras. In my opinion, I wouldn't bet on it. They didn't even activate the ability for you to see it in the app until the last minute as their advertised deadline approached.
Accessing Local Storage
