At this time the Ultra can only run on the Ultra base.
But, you can add the Pro/2 cameras to the Ultra base as it is backward compatable.
Perfect, Thank you!!!!
You can also run the old base station (with its alarm) side by side with the new hub (no alarm). "Rules" can then link devices on the two base stations.
So an Ultra camera on its hub can trigger recordings on a Pro 2 camera on its base station.
Just another user
Thanks for the tip!
Dealt with here:
Solved: Re: Can I add the Arlo Ultra to my existing Arlo P... - Arlo Communities
Just another user
Accessing Local Storage
