At this time the Ultra can only run on the Ultra base.
But, you can add the Pro/2 cameras to the Ultra base as it is backward compatable.
Perfect, Thank you!!!!
You can also run the old base station (with its alarm) side by side with the new hub (no alarm). "Rules" can then link devices on the two base stations.
So an Ultra camera on its hub can trigger recordings on a Pro 2 camera on its base station.
Just another user
Thanks for the tip!
Dealt with here:
Solved: Re: Can I add the Arlo Ultra to my existing Arlo P... - Arlo Communities
Just another user
						Accessing Local Storage1
						Arlo Mobile App282
						Arlo Pro 31
						Arlo Smart180
						Arlo Ultra9
						Before You Buy434
						Features290
						Fehlerbehebung1
						Firmware Release Notes39
						Installation300
						Online and Mobile Apps113
						Service and Storage110
						Smart Subscription3
						Troubleshooting1,827
