  • 5 Replies
  • 2385 Views
wonkypenguin
Another day, another problem... do Arlo even bother testing their software? 😞
I have ultra cameras on an elite subscription plan. Live view and cloud recording are in 4k, but the base station recordings are only 2k.
Anyone seen this? Is there a solution?
5 REPLIES 5
ShayneS
Hi @wonkypenguin
Just to be clear, You are referencing the local 4k recordings correct?
wonkypenguin
Yes. My cloud recordings are 4k and crystal clear, the ones on my base station SD card are 2K and grainy
wonkypenguin
Cloud...
wonkypenguin
Local/base station/SD card...
(Also the broken preview, that's another bug if you cancel a download to your phone and start it again)
ShayneS
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
  • 5 Replies
  • 2386 Views
