ADPC,
The outdoor cable is a weatherproof design, whereas the indoor cable is not. (the usb end of the indoor cable is not weatherproof)
I don't currently have information on the UK release for the outdoor charger. The US version of this should be available on amazon May 8th.
i will provide an update when I know more.
![michaelkenward michaelkenward](https://community.netgear.com/legacyfs/online/avatars/f_98444_Monitorsquare85.gif)
I plan to install one of these when I get round to it:
Available from other suppliers!
Big enough to supply power to various Arlo and Orbi stuff.
The Arlo indoor cable should be long enough, and a generic power adapter can deliver the power over USB.
Just another user
Hello SillySam,
Thanks for your advice/suggestion. Appreciated 🙂
I had considered that option as ultimately thats what I plant to do. i.e. Taking the USB charge cable between the brickwork/upstaris window frame and into the house so it can be powered via a internal socket/usb. The only problem here is that the power cable that came with my kit is only a metre long so utterly useless for this scenario. I don't believe there's along (8m?) internal or external cable available in the UK at the moment.
I have to admit is seems utterly ridiculous that you can spend over £1000 on a 4 camera ultra kit only to be supplied with one pathetically short power cable, I'm sure that the majority of Ultra cameras (costing over £300 each) will be positioned well above the reach-height to stop them being stolen (an increasing common problem with the Ring doorbells I believe) . Therfore, I epect most will want to have the cameras permanently powered so you don't want to be getitng the ladders out every few weeks just to remove and recharge the battery.
Come-one Arlo, you have a great product here and you're letting yourselves down by
1) Not including a decent USB lead for each camera.
2) Not having the cables avaialvle for purchase in the UK (at a reasonable and fair price)
Let's get this sorted please so we can move on and complete our Arlo Ultra installations 🙂
8 feet seems to be the limit at the moment.
"This item will be released on April 22, 2019."
But at £21.99 I'd hate to think what a longer cable would cost.
Guess that would work with a bit more DIY patching together.
Just another user
Forgot to mention I picked this up for it to work, sorry..
I'm in a similar boat to you. I have the ultra 3 camera setup which are currently sat in a drawer until the waterproof charge cables become available. I'm not climbing up to the roof 3 times every week or so to recharge batteries. The charge cables (VMA5600C) are available in North America and Australia for pre-order. I've checked various European suppliers and they are not available anywhere. I thought it was an oversight when it didn't appear on Amazon.co.uk but because no-one else has them it appears deliberate.
So, at £900 I have 3 very expensive paperweights until Arlo can get their act together.
I had a similar problem. I've bought and installed: Arlo Solar Panel Charger (VMA5600). Battery was charged from 61% to 100% within five hours. Not available in Europe, yet. I ordered from Amazon USA.
Thanks for the intel and planned release date. Sadly this looks to have been pushed back to June 03rd on the Amazon site 😞
I find it somewhat incredulous that a simple 5V USB cable can be so hard to produce and distribute. Also the price is absoutely astonishing. I'll probably wait until a 3rd party create an Ultra magentic USB charge cable that does the same job for a couple of quid. I'll post here if I ever find one 😉
Not sure I'll be buying additonal kit from Arlo. They're having a laugh at the price of accesories. i don't mind paying a premium for the cameras, as they're top quality, but not for a basic USB charge cable.
It is even more baffling when you think that Arlo postponed the launch of the Ultra. Some escaped through BestBuy in January. Then it got pushed back to April.
Had things gone to plan, then, the gap between cameras and accessories would have been even longer.
I can't see that they needed extra time to make adapters and cables.
Just another user
I ordered on Amazon 2 of the "Wasserstein 25ft/7.6M Weatherproof Outdoor Magnetic Charging Cable with Quick Charge Power Adapter Compatible with Arlo Ultra"
They arrived today. They work fine. I cannot visually detect any significant difference with the magnetic attachment of the original "indoor" cable supplied with the unit.
There was an initial problem with delivery, but Wassertein and/or Amazon fixed it very efficiently.
I paid $35 each. I see that now they are not in stock anymore. I will be ordering another one when back in stock.
I'm deeply disappointed in Arlo at this point. They really have no excuse.
The Wasserstein weren't on Amazon when I ordered mine and so I purchased the Pavora brand for $22 each. I can't see any difference in them. When looking at the Arlo ones, the magnetic end also looks identicle. What I can't see is the USB end of the Arlo ones. I'm not sure any USB end would be waterproof if completely in the open. The Pavora brand I got works great and at half the price of Arlo I will get them for all of mine. However I intend to run a line up under my eaves from my outdoor plugs and or lights and install the USB power plugs you can get at any home improvement store to fit an electrical outlet to plug them into.
I was looking at the Pavora cables for use here in the UK... are the chargers supplied 110-240V or are they 110V only? ( Mind you, even if I had to throw the chargers away, the cables are still cheaper.... and actually available! )
They are supplied with 100-240v power supplies so yes they should work (I'd check the power supply first though as it should be written on the case somewhere). You'll need a US to UK adapter of course. UK USB power supplies will work too so if you have any old phone chargers they will work too as USB only uses 5 volts. I've ordered three of these with the expideted delivery and the look to be delivered to me in the UK within 7 days.
Yup, in the same boat. Really frustrated as I wanted to use it on continuous mode and can't as I need a cable that hasnt been released in the UK yet.
So basically I spent £700 on an item I cant use! Thanks Arlo.
And its ok in the rain? That cable isnt meant to be weather proof which is what is worrying me.
If you use USB extension cables as suggested you can use self amalgamating tape to seal the joins. This still leaves the issue of getting hold of the Arlo charging cables if you need more than one... the 8 foot ones seem to be available in the UK now but are rediculously expensive.
I just bought 4 of these from the US:
Arlo Ultra Power Cable and Adapter, Magnetic Charging Cable for Arlo Ultra 25ft/7.6M Weatherproof Outdoor or Indoor Cable with Quick Charger Power Adapter Compatible Arlo Ultra
I bought the Pavora cables too. Arrived within a week and came with power supplies (albeit US but multi-voltage so will work on 240v).
They are cheaper and even the postage was reasonable. The Arlo official cables are twice the price at $50 and no doubt the taxes added are going to be double too.
I've been using them for about a month (outdoors) and no problems so far.
Buy the pavora cables from amazon.com. They are half the price and arrived within a week. I got sick of waiting.
Amazon keep pushing the release date back and no information form Arlo. What’s going on?
Accessing Local Storage
