Arlo Ultra timing out Pro Base station
Have an Arlo Ultra connected to the Arlo Pro2 Base station. Works fine and get clear 4K resolution.
However every few days it freezes and I have to reset the base station to get connection again. Got full wireless signal. If its frozedn when I try live I get 'The request timed out'
Base station: VMB4000r3
Firmware 1.1515.0.1_3162_d8788
Camera: Arlo Ultra H8
Firmware: 1.070.50.2_205_0c7c8e1
Try restarting your wifi router/AP and then restarting your Arlo base station to change what channels they run on. See if that helps
Thanks, will try that. Is there a way to see what channel the base station is using?
I forgot to mention I do have 3 x Arlo Pro 2's running off the same base station and can still connect to them when the ultra fails to connect
You can download one of many different "wifi analyzer" apps that show all the nearby networks and what channels they're running on plus signal strength etc
Make sure your router isn't broadcasting its 2.4GHz network on Channel 13
I think this is normal. I have to reboot my base every 2 days to prevent this proactively
You could get another base station or Arlo SmartHub but you really shouldn't have to. You said Wifi Analyzer said you could use channel 11 as it's the clearest? So if you log into your wifi router and change the 2.4GHz channel to channel 11, then restart your Arlo base station, Wifi Analyzer should tell you that both your wifi and VMB base station are on channel 11. See how that goes with regards to the Ultra dropping off
Accessing Local Storage
