Is anybody else experiencing a problem where Arlo Ultra cameras stop recording / don't "play" anything unless I boot the Ultra SmartHub. Problem was more severe when I had memory card installed in the SmartHub. Cameras are online, just don't "play" any movement. Each SmartHub has at least 4 cameras installed.
SuperSamuli,
Do you see any error messages? What do you mean when you say they don't "play" anything? Are you getting recordings?
Nothing gets recorded. If I click "Live" -link, I get "Please wait..." and then "The device failed to connect. Please try again" error. Rebooting Smarthub fixes the problem, but I have to do almost daily.
SuperSamuli,
This could be a connectivity issue with the cameras. Poor signal strength due to range or interference can result in the cameras struggling to maintain their connection with the SmartHub. What does the signal strength icon show for the camera?
Can't be that - getting 2-3 bars on all cameras. And this happens with all the cameras connected to the same SmartHub. And problems occurs with several SmartHubs as well. This morning I had to reboot three out of seven SmartHubs that I have here.
Update - I have been trying to solve this issue where approx. 10 cameras out of my 50 cameras simply stop recording every day. Problem is probably caused by having too many cameras on the property (I have 50 cameras around 2 acre property). I'm going to wait until next firmware / software update comes out - hopefully solving this issue.
Accessing Local Storage
