  • 8 Replies
  • 3505 Views
  • 5 In Conversation
HazzMatt
For the last several days, some of my Arlo Ultra Cameras have missed motion detection. Also, 1 of my cameras appears to be online but it struggles to come up in live view, despite having the normal 2 bars of signal strength which is typical for that camera. After various troubleshooting, resets, removing and replacing batteries and redoing the pairing process with no success, I decided to check to see if there have been any firmware updates. There is one for the Arlo 5000 Base, released just a few days ago and the date coincides with the date of the start of my issues. My Ultra systems had been working pretty much flawlessly for many months until the latest big fix base firmware came out. For the first time in a long while, it appears I'm back to an unreliable system, seemingly caused by a firmware update.
8 REPLIES 8
Try rebooting your hub and maybe removing and reinserting the camera batteries.
HazzMatt
Thanks for your response. Please read my post again and let me know if you have any suggestions not already tried.
ShayneS
HI @HazzMatt
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.Arlo Tech Support
Jsijnja
I am experiencing something similar in the past week or two with motion not being detected on a particular camera when previously it seemed to be working reliably
ShayneS
HI @Jsijnja
There are a few steps we can try.
  1. Reboot your base station
  2. Remove > Re-Insert camera battery
  3. Remove camera from Settings > My Devices > Re-Add
SamuelR
I'm also having the same issue with two of my four Arlo Ultra cameras. So frustrating. Tried the steps listed.
ShayneS
HI @SamuelR
  Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
SamuelR
Hi, @ShayneS
I'll get in touch later today or tomorrow. I'll try resetting the whole system again first and see if it changes anything.
Thanks!
  • 8 Replies
  • 3506 Views
  • 5 In Conversation
