Arlo SmartHub - VMB5000 whats the hardware difference between the different revisions, r4 vs r6?
  • 2674 Views
Robi1970
I would like to know what the differences are between the different revisions of hardware of the VMB5000.
I have both r4 and r6 and would like to know if there the r6 is better due to higher revision of hardware.
Should I change/upgrade my r4 to r6?
I have Video Doorbell/Pro2/Ultra/Ultra2 connected to the hubs.
AFAIK, All hardware revisions have the same specs - so no need to purchase new bases.
Hardware revisions are generally due to parts availability or doing some cost reduction.
Robi1970
Ok.
Thanks!
So the Arlo Ultra 2 - extended range is built in the cameras  - not the hub?
I assumed (wrongly then) that it might be a combination of hardware updates in both camera and hub that resulted in the extended range.
Yes - but hopefully @JamesC will confirm.
Note the max range is spec'd at 300 feet for both the ultra 2 and the ultra - so the improvement is in the practical range, not the max line-of-sight.  I don't own an Ultra 2,  so I don't have any first-hand experience.
  • 2675 Views
