My Arlo Ultra Hub stopped connecting. It lost connection to one camera at a time until it wouldn't connect to the internet anymore. The same ethernet cable works with other products. Attempted to factory reset and does not work. Held button for 10+ seconds ever time with zero changes. Had system for 4 years.
Justinjsimms,
This could indicate hardware failure. What is the LED behavior on the SmartHub after a factory reset?
It won’t actually reset. It will stay blue and never connect or stay Amber and never connect. I probably need to replace the hub but was hoping to avoid the expense.
Accessing Local Storage
