  • 1 Reply
  • 655 Views
ppress
My 3 cameras and base are less than a year old.  When it was time to charge one of the cameras, it didn't flash blue when attached to the charger, and it wouldn't charge.  I tried unplugging/rebooting the base tower and this seemed to get the camera charging (i.e. it flashed blue).  It charged normally, and I remounted it outside when it was fully charged.  Everything appeared normal.  However, it began to drain immediately and within one day had 0% charge.  The question is:  What do I do when my camera won't hold a charge?
Product:  VMC5040
Firmware:  1.070.52.1_35_1bdb65f
Hardware:  H7
One test is to swap the camera with one in a different location - to see if the problem moves with the camera or not.
A similar test is to swap the battery with one in a different camera, to see if the battery is the problem [or not].
Once you've sorted it out, if it is the camera or battery, you can contact support (using the options in the app), and ask for a replacement.
  • 1 Reply
  • 656 Views
