Android app (2.20_28160) crashing on Samsung S10. Tried reinstalling app.
  • 6 Replies
  • 2537 Views
Vij
My arlo app keeps crashing on my samsung s10. I have deleted and re installed the app from play store but as soon as you click on the app it crashes.
My app version 2.20_28160.
Can someone please advice what could be the issue.
JessicaP
We recently released a new version of the Arlo Android app, which is 2.20_1. Update to the latest version if you haven't done so already and let us know if you're still seeing the issue. You can read more about it here: Arlo Android App - 2.20.1 - 28th September 2020
6 REPLIES 6
JessicaP
Hi Vij,
What Android version are you running on your Samsung S10? Is this happening when you're on WiFi and/or cellular data? And if you have VPN on, try to turn it off to see if that helps as well.
Vij
Hi Jessica,
Thanks for your reply. I'm using version 10 of android. It crashes on both wifi and cellular. I do not have vpn setup.
I have noticed when i go to play store and open app from there it works fine. Directly it crashes.
moeman
The exact thing is happening to me.  Samsung S10, crashes when I open the app directly but opens from play store.
Seattlegrunge
Happens to me too on Samsung Galaxy S9 Note with Android 10 and latest updates. It has been going on for a couple of weeks now.
moeman
I tried mine again this morning to send the logs to Arlo and it opens fine now.     I also woke up to an update for android.  The app opened before the update and after the update.  Any one else having the same luck?
JessicaP
  • 6 Replies
  • 2538 Views
