Hi everyone I’m not the only with issue.
I’m reading the features on the 4K FYI think the 4K is only available recalled it the way subscription or it Hass to be hardwired please correct me if I’m wrong about this.
I only really need the system to alert me if someone approaches my house I was wondering do you guys think is the 4K worth the extra money thanks for any help and advice that any want to give me
If your just looking for a more basic system without the higher end features, then there is nothing wrong with the Pro2 system. It detects people at about the same max range.
If at a later date you want more, the cameras will work with the Ultra system.
The Ultra system is a step up from the Pro and Pro2 systems. You will have to decide if the 4K recordings are worth it to you to pay the extra cost of the PVR for each camera that you wish to record 4K on. The Zoom and Track feature does not work with 4K. The Siren is no longer included in the base, but instead, it is in the camera itself and the volume is pathetic.
That being said, the built in spotlight with color recordings and the Zoom and Track features, the larger battery and automatic selection between 2.4 Ghz and 5 Ghz deoendibg on signal strength is, in my opinion, a game changer even if you never use the 4K recordings. The cameras do work on batteries although for CVR and Activity Zones you will need to connect the cameras to a power source using Arlos AC adapter and magnetic cable.
I now have 5 Ultra cameras and I really like them much better than my Pro and Pro2 cameras which are quite good cameras.
I have not tried it, but The Ultra cameras will work through a window.
Brian
For clarity, Arlo Ultra will not detect through a window. Please see this thread for more information: https://community.arlo.com/t5/Arlo-Ultra/Does-Arlo-Ultra-detect-through-windows/m-p/1687632#M2186
I pick up the pro 2 and at the moment it was very easy to set up after a firm wear update.
? I want to give my wife access but only to view the footage is there way to do this.
Thanks for any help and advice
@Flex1493 wrote:
Hey guys thanks again for the help and advice.
Start here:
Get the manual for your device.
Read the section Grant access to friends.
Just another user
@Flex1493 wrote:
Well once again guys thanks again I was under the impression that it will work through a window if that’s the case then I guess I will stick with the Arlo pro 2
FYI, the Q camera is the only one that works thru glass as it uses pixel detection( tho you can't use the IR night vision as it reflects off the glass ). ( pics thru double pane anderson window )
If you have outdoor lighting, the Q works well even at night.
I pick up a 2 camera set but still want one for the windaw
I’m going to look it up online and see if I can find something.
Go to settings... Grant access ( follow instructions ), send to other email invite
Try and read thru the FAQs...almost all questions have been answered before
Go by the SUPPORT Articles
Now I’m trying to figure out we’re to mount them. Lol
Accessing Local Storage
