  • 13 Replies
  • 3820 Views
minhpham
around 10 pm on 3/1/2023 is the last recording I got. It happened before back in Dec 2022 but it did come back after a week. this time it doesn't seem to come back. does anyone has the same problem?
thanks,
@minhpham wrote:
there is an error message. it said video stored on base station are not available. please check your connection setting.
Try putting the phone into airplane mode and then enabling wifi, to force the app to use your wifi.
13 REPLIES 13
Have you tested it yourself? Maybe nothing happened within range of the camera.
minhpham
Yes. The camera is in front of the house so it capture all the traffic. It was fine until March 2. Nothing get change in settings. I reboot the station multiple time but same thing. I got the notification when it see motion but no local record. Thanks for the reply
Do you have other cameras connected to the base?   If so, are they recording?
If there are no recent recordings at all, you could try reformatting the card, and see if that helps.
minhpham
I do have another one in the back and it the same problem. I did reformat the sd card twice and that didn’t help. I can see that it recording when there is motion but not sure where it recorded to. When there is motion, I can see the recording icon turn Orange for about 10 seconds but not sure where it records to. Thanks
Have you plugged the microSD card into a PC and looked for the files?
minhpham
yes and the sd card does have the recording but arlo software said no recording at base station. with the sd card connect to my pc.  I can view the recording on my pc.
Ok.
As you likely know, local recordings can only be accessed from the app, and not my.arlo.com.
Does your app show "Library" on the main menu?  Or does it show "Feed"?
minhpham
I don't use my.Arlo.com on my pc. I use my pc to access mp4 files and play from there. I always use my Arlo app on my iPhone to look at local recording. It does show library and base station not cloud. I haven’t change my setting at all. It was working for 5 months until that update in dec 2022 and it was stop recording for a week and it start again until March 2 2023. Thanks for the help
When you choose the base station in the library, are you getting an error? Or just seeing no recordings?
minhpham
there is an error message. it said video stored on base station are not available. please check your connection setting. how can it be my setting. I never change my setting. it still set for record locally turn on, storage status is ready, and direct storage access is turn on. thanks
minhpham
thanks that work. not sure why the phone doesn't go thru wifi first. thanks for the help
 Me either.
I think you'll find that it works now even when you don't go into Airplane mode.  Let us know either way.
  • 13 Replies
  • 3821 Views
