  • 8 Replies
  • 2066 Views
  • 4 Likes
  • 7 In Conversation
yautsz
Unable to login my account via Arlo Secure Apps in Android device and shown "Oops, an error has occurred. Try again" but it could be login my account on web browser.
yautsz
Just try it again and it seems to be fixed
8 REPLIES 8
yautsz
I found the problem that is my IP/location in Hong Kong.  If I change other location via VPN then login is successful.  Is support could fix it?
Alberty
I encountered the same problem today in Hong Kong.
One thread on this is sufficient.
SamHung
Same here
Leo999
Same here,but I don't have vpn.so sad
musume
Bro same here. Location in HK, successfully login through website but not in the app since yesterday. Only can use the app to login by using VPN.
yautsz
ShayneS
Thank you for your feedback. This issue should now be resolved.
