  • 1 Reply
  • 1058 Views
kng112
        "Charge battery"
"This device's battery level is too low. Connect a compatible charger to charge the battery."
one of my camera show on the screen saids, charge battery when i view on desktop, but on my phone said fully charge, i've take out the battery and put it back, removed device and re-connect to the hub, but still saying charge battery, any suggestion to fix this? all cameras are 3 months old only, would it be a battery issue?
@kng112 wrote:
        "Charge battery"
my.arlo.com is often showing stale (incorrect) status.  That is something Arlo needs to fix.
In the meantime, rely on the app for the correct charge status.
  • 1 Reply
  • 1059 Views
