  • 7 Replies
  • 1646 Views
keislee
I just installed my Ultra 2 cams few weeks ago and recently could find there is moisture/water condensation on lens (inside), I can clear it easily if it is outside. But I found it is the len side in the cam? Is it normal? I assume it is waterproof and should have moisture getting in. The moisture blocked large area of the video and pictures. Please share your view if u have experience to this?
BrookeN
Please contact support. Within the app on your mobile device click on the silhouette on the top left ~ support center ~ the device that you are needing assistance with then choose the issue.
7 REPLIES 7
It shouldn't be inside the lens.
You might want to take the camera out of the housing and check the O-ring.
keislee
Thanks for your sharing. But how do I check it or I should send backk to Arlo for checking?
Just take a look at it.  See if it is stretched or damaged in some way.
Applying a bit of silicone grease to it can improve the water resistance some, and also makes it easier to remove the camera from the housing.
keislee
May I know where is the O ring?
Take the camera out of the shell.
It is the thin rubbery gasket that goes around the camera body right behind the camera face.
keislee
I have contacted Arlo CS for a week but still no one reach me till now. Disappointed
BrookeN
  • 7 Replies
  • 1647 Views
