Change of camera position notification ultra 2
  • 2 Replies
  • 718 Views
rcsilber
Is there a way to eliminate notifications of a change of camera position, or a change in activity zone?
My cameras and activity zones are set, yet at times I get a notification that either a camera position changed or an activity zone changed. In fact they have not. The problem comes with Arlo decides to send that notification during the night while sleeping.
Any way to change or disable this type of notification. I have searched the settings and don't see anything obvious.
No setting to do this. A bird may have landed on the camera or even a strong wind gust to cause this. I've seen it a couple of times but I was mucking about with the camera. You could try tightening the mount to prevent this, depending on the mount.
rcsilber
Thanks for your knowledgeable input. Sadly, I've already done what you suggested. The mounts are tight... what's bothersome is when I get a notification that activity zone(s) have changed, the zones are in fact just as I left them. I'll put a memo out to the birds to be kind and not disturb the Arlos 😉.
  • 2 Replies
  • 719 Views
