No notifications, not detecting motion but it's possible to livestream.
  • 929 Views
Jonarild
Help is nedeed.
My arlo #ultra2 do
not detecting motion.
I have traid averything. Adjusting all of the setings, and tryed to reboot it. But nothing works.. help me pleas.
@Jonarild wrote:
Help is nedeed.
My arlo #ultra2 do
Are you getting notifications but no recordings?
Or are you not getting notifications either?
Can you livestream the camera?
Jonarild
No notifications, but it's posible to livestream.
First I'd run the motion detection test.
If you see "Library" in your app menu, then instructions are here:
If you instead see "Feed" and "Dashboard", then instructions are here:
Assuming that fails:
If you have a subscription, you could try using phone support.
Another path is try a hardware reset of the camera.  You'd need to
  • remove it from the account,
  • open the camera, and press the sync button until the LED flashes amber (about 15 seconds)
  • add it back to the account.
  • 930 Views
