Local Storage Viewing with Smarthin 5000
  • 1 Reply
  • 964 Views
  • 1 In Conversation
Mowestbr
Spoiler
I am unable to see my locally stored video on the Arlo App.  It is set up per the instructions of the support prior to my trial subscription ending.  I do not want a subscription.  The data is on the card, the smart hub is enabled to allow viewing and local storage.   Nothing in the “Library”.  Calendar is grayed out and says no recordings.  There are no recordings past the trial ending date, but plenty prior during the trial.  Help!  This is useless without recordings and no access to support.  I have restarted everything to see if it would help.
Mowestbr
Well, I kept trying things and finally got the local storage visible by uninstalling and reinstalling the Arlo App.  I had tried all the devices restarting  and had tried logging out and in, but uninstalling and reinstalling the app got the recordings visible.
  • 1 Reply
  • 964 Views
  • 1 In Conversation
