Hey guys
so more issues with the Arlo Ultra 2
The last couple of days I been getting a random pop when I try to go live stating the "device is unreachable" however after I click the X a couple of times it's back to normal sometimes it's even live under the popup..
I have not changed anything Internet or setup wise and I have tried to restart my Smart up and it's made no difference.
I see this problem is being experienced by several others. I've tried all the recommended fixes. Nothing works. The hub seems fine. I tried deleting one camera & reloading it. Nothing. On Aug 1 "Shayne" said that the Arlo team was looking into the problem. Has anyone heard anything? I've been without security since July 27th. Arlo is starting to feel unreliable.
So, after the most recent app update on iOS and a full base station reset, all my cameras and the chime are connected and working again. I can’t enjoy that too much, though because I can’t login to my.arlo.com from my PC any more and I cannot add my Audio Doorbell, which used to work well. One step forward, 2 back kind of a situation.
That should still work - what happens when you attempt to log in there?
I have been having this same issue for about a month now with different cameras being unreachable at times. No change in internet, subscription or positioning of cameras. But I almost always have at least one camera unreachable at any given time. I have 8 cameras on my system and my internet coverage is excellent on my property. Really frustrating. Many times if I remove the battery and reinstall it and will reconnect but that is not ideal to keep doing as some are not easily reachable and doesn't always work. If I restart the hub it sometimes comes back but it's all random.
I'm using android phone, fold 6.
I get this “No Internet” / Request timed out error. The forum is full of it, apparently when you login too much with different devices, which I did for troubleshooting, that locks you out perpetually. Had I known…
@StephenB & @ShayneS can we please get some sort of update , im starting to loose my patients, not only did I like many others here spend $1000 on the cameras, smarthub, solar panels and door bell but we are also paying an $18 a month for a subscription... this is unprofessional and again it feels like they keep breaking things every update...
P.S not angry at you guys just frustrated paying for something I cannot use.
I am having the exact same issue. I thought I was going crazy. This has been very frustrating. This is an obvious software issue that they need to fix ASAP. I have the subscription and personally would like to be partially compensated for the last few months of this mess.
I used to have 4K on live video, now I have a very bad quality and the base station is not registering locally since 5 august
someone experienced this?
I have Ultra 2 cameras with latest Base Station, I’m running iPhone 16 Pro
I have full subscriptions
I’ve reset the base station and cameras are set to maximum quality
Yeah on top of the original issues I posted above , when my cameras do work livestreaming in 4k is about 5% and the other 95% is "live" only and very blurry.
Sadly I dont have local storage setup but im sure if I did that would be broken too.
Arlo Ultra 2
Prima di acquistare
