I bought 2 more cameras with a smarthub because it was cheaper than without the hub. Can I use both hubs for better performance ?
It would be useful if you have any cams farther away from your original Hub with lower wifi signal to put the 2nd Hub closer to them and pair those cams with that.
Arlo Ultra 2
Prima di acquistare
