  • 1656 Views
keyboardxbully
recently the schedules in my automations either do not activate at the time i have set, turn themselves off or arm 1 hour earlier than the scheduled time. i upgraded devices after the end of life for the older units was released, and the app updated to the new version to support the new cameras, i had no issues with the previous app version when it came to my schedules working properly, is this common? should i delete them and start fresh? im at a loss at the moment.
app version-4.1(5991)
base statoin-vmb5000r6
ios-16.3.1
Schedules have been a bit problematic. Try using one minute before or after the exact hour to see if that helps. The issue of the schedule switching an hour early may or may not be related to the upcoming change to daylight saving time this Sunday. We'll see...
Douglasp71
Having a similar issue, I have an automation setup to disarm cameras in the morning on a construction site and when I go to check it it says it's turned off, but all the other automations are activated.
keyboardxbully
I eventually deleted all of my automations and set them all back up and so far so good, try giving that a shot.
  • 1657 Views
