All my 4 cameras can not be found after the power adapter went dead and replaced by a good one.
@Chilin wrote:
The new problem is how do I deal with my wife on my "not a handy man" and laugh at me for many days. Can you help on this!
Just go with it. I think she has proven she is the right person to keep your cameras running. Worth a few laughs. 😀
Is the base still on-line?
Stephen:
@Chilin wrote:
Now my new problem is one camera with mounting tool that I need to use the pin to push to get camera out of the cover and I heard a click but the camera only came out a bit and it did not have room for me to to pull the camera out of cover.
I find that pushing the release again sometimes helps (though I don't have any cameras that have the total security mount). You could also try using a utensil of some kind to try to pry it out (maybe a plastic knife????)
Once you get it out, I suggest applying some silicone grease to the O-ring.
Stephen:
Thank you very much. It worked.
However, I have tried 10 times in 2 days and no luck. Before I gave up, I asked my wife to try, just in few seconds, her pin push got the camera came out more as normal. Now the camera issues are all resolved.
Regards,
Chi
Stephen:
Thank you for giving me the strength to deal with the boss in the house.
Regards,
Chi
Arlo Ultra 2
Prima di acquistare
