Arlo Ultra 2 vmc5040 Camera is Not water resistant 2 down
Arlo Ultra 2 vmc5040 Camera is Not water resistant 2 of 4 cameras are down
Last one had visablle moisture inside.
Guess Im going to have to Point it downwards to prevent any rain gatting in.
Think im gonna have to build a roof over each one so they do not get wet
firmware new os android
This sounds like you didn't fully seat the camera into the case. There's an O-ring that can make it tough to get the camera in and out of the case but that is needed for the weathersealing. I find it easier to seat the camera into the case by placing my thumbs on the edge of the camera face while wrapping my hands around the case. Pushing with my thumbs until the camera clicks into place causes the seal to be complete and weather-tight. If you didn't hear the click, it's not properly seated.
Arlo Ultra 2
Prima di acquistare
