Arlo 25ft charging cable be plugged in continously to ultra 2 camera?
I'm installing cable outside and would like to leave it permanently plugged into Arlo Ultra camera, will it damaged battery or over charge?
The cable is removable if that is what you're looking for?
After reaching 100% charge, it will then be trickle charged slowly. You can also remove the battery and power via the cable if you wish.
Arlo Ultra 2
Prima di acquistare
