Activity zone disappeared
I have the ultra 2 system with 4 ultra 2 cameras. 3 are hardwired 1 is solar. I have 1 pro 3 spotlight.
All of the ultra 2 cameras had the activity zone disappear. It is still there on the spotlight.
I’m on iPhone with latest updates.
I’ve restarted the hub and power downed my phone. What’s the fix? I’m assuming it’s on arlos end needing an update.
On a different note. The IR cut filter noise would make me not buy these again until it’s fixed. At least add a manual override or sensitivity option to stop tv light from having it constantly clicking.
SeaCow,
Are you able to add activity zones after this happened? If you set up a new zone, does the same thing occur?
Have you logged in from a PC or another device to confirm you see the same behavior?
Arlo Ultra 2
Prima di acquistare
