- English
- Arlo Forum Discussions
- Arlo Stories
- Re: Arlo Service Down - Temporarily Unable to Logi...
Dear Arlo Customers,
Thank you for your patience. Arlo services are now fully restored. We sincerely apologize for any inconvenience this has caused. The disruption in service which affected some of our customers was due to a technical issue that arose during routine system maintenance.
Thank you.
-The Arlo Team
Please click KUDOS or REPLY If you found this helpful.
A few things you can try.
Power off the base station for one minute and power it back on.
Unplug the ethernet cable and power from the base. Reset your router then plug the ethernet cable back in and power up the base station.
Lastly, do a factory reset by holding in both the sync button and using a paperclip holding in the tiny reset button at the back of your router until all theree base lights blink amber, (about 10 to 15 seconds.. Be advised that doing a factory reset will remove all your devices and you will have to add back the base and then sync each camera back into the system. Only do this as a last resort.
Brian
Please read this article. I don't know if they really enforce the 90 day rule or not, but I don't think so.
Brian
I still cannot get my cameras to work. it says getting status is all it will do since they went down
Please let us know what the LEDs on the base station and on tthe cameras are doing. It appears that the cameras are in your system, but not synced to the base station.
Brian
Please let us know what the LEDs on the base station and the cameras are showing. Also what have you done so far to resolve your problem? Lastly what is going on in the app.
Brian
yes i am / have an ARLO GO and being told i must physically reset the camera... i bought it because it works with VerizonLTE and is designed for remote usage. Arlo / Netgear had some BIG hack or service disruption and then simply told every one "temperary outage" then said all systems are back online / i am not and sounds like you are not too..
they pushed out a new software revision / when Apple does it it doesnt take down every ones system..
Arlo definitely needs to do some more work to stop this inability to reset and restore the systems It seems there should be some commands that can be done by their customer support department from their end, or better yet some buttons in your app to reset and restore the system.
Brian
Have you tried resetting your modem?
I also have the original system with 3 original cameras and 2 Pros on the original base and everything is working fine.
If the system says your base is offline then it has not synced with the internet or for some reason your base is not getting an internet connection.
If a camera says it is offline, then it is not syncing with the base station.
What we need to do is to find out why your base is not connecting to the internet. What is the middle light on your base showing?
Here is a link to show the meanings of the lights on your base.
Brian
I finally got one of my cameras back online. I had to drive to camera location and restart camera by removing and reiserting battery and worked automatically. This is a bad situation for those whom have cameras in remote locations but is the only way I found to get one of them going again. Hope this helps.
Oh, It shows that the cameras are offline, what about the base station?
Is it also showing offline?
After a factory reset you must claim your base - in other words you must add the base station back by adding in the device section of your app then add each camera and resync it.. Also, none of your devices should be showing. as a factory reset should delete everything from your system. In other words, you are starting again from scratch.
If you are still seeing your devices you did not properly do the factory reset. Delete everything from your system. Using a paper clip and hold in the tiny reset button until all the LEDs on the base station blink amber.
Wait for the base to reboot then go back into the app and add the Base. If successful, add the cameras one at a time and try to resync.
Brian
Was down across the board then it was just fixed and running again.
They did not say why it was down as far as I can see and no real explanation
My camera is still down and they say I
Must physically reset it. I live 300 miles away and that’s why I bought the Arlo Go with Verizon
You may be right or it could be the cloud servers went down. I have had similar problems lately on Smartthings with global cloud outages. It seems that whenever there are severe storms the clloud acts up. I don't know where Arlo or Smartthings have their cloud servers, but I believe that when the problem started, there were severe storms and power outages in the midwest and northeast.
Brian
Now told I have manually reset it and that’s a 300 mike drive. (Each way).
Been through 2 panels and now using 120 vac power and still get same message after 4 days. “Battery not charging / use an Arlo brand source” well I am
It could be some tolerence between the battery terminals not making good contact with the terminals in the camera. I read that someone used a thin piece of cardboard behind the battery to hold it in place until they could swap the camera out.
Also check for bent pins on both ends of the cable and in both the solar panel and camera plugs.
Brian
Nooooo it’s non of that! I went thru the whole thing with Netgear. They really didn’t want to help as far as I’m concerned! Now I’m stuck for 2 years with something that doesn’t really work.
