arlo smart shows only 7 days of resordings
  • 4 Replies
  • 11163 Views
  • 2 Likes
simlatarlo
Hi,
I am an arlo smart subscriber
the library is supposed to hold 30 days of resordings (that's what i pay for)
yet it now shows only 7 days of recordings
what to do?
thanks
dcfox1
@simlatarlo wrote:
thanks for your reply
yes, both cameras are active, the subscription part shows both of them
the library looks exactly like you DON'T have a subscription - 7 day of recordings
thanks
Don't know why that is but you can try removing them from in the sub in the "manage camera" setting and re add them in the settings. Also you can change the plan to the new arlo secure for the same price to see if that makes a difference but don't think it would .  You can do that in the sub setting also.
dcfox1
@simlatarlo wrote:
Hi,
what to do?
thanks
Have you checked to make sure the cam or cams are active in the subscription in the subscription setting where you can manage the cameras active in the sub.
simlatarlo
thanks
dcfox1
thanks
simlatarlo
thank you!
