  • 4 Replies
  • 3809 Views
GraemeMitchell
I am trying to view my library recordings, if I turn off my wifi on my iPhoneX the video plays fine.  As soon as I am on wifi the video doesnt play, just spins.  I tested the speed 100mbps download and 77.4 mbps upload via SpeedTest when I am on wifi.  I have checked the firewall to see if something is blocking ports/addresses etc and I cant see anything
Yup, the library video is being pulled from the cloud. It sounds like your network is the problem but try a different WiFi (neighbor/friend/public hotspot) to verify this.
Try rebooting the phone. I don't recall for sure but I think I've seen a few comments about iPhone and WiFi needing to be reset. A search may pop this up for you.
GraemeMitchell
I reset the iPhone network setting, deleted the app, re-downloaded the app and its the same.  When I click to see the "Live" view it takes a few seconds to connect and then it shows the live feed.  Its just the library files that dont play.
I assume that the library files are on the cloud and the live feed is the app tunneling to my home and it isnt going to get anything from the cloud?
GraemeMitchell
damm, you are right.  Flipped to the neightbours network and it works fine.
