Can someone help? I'm trying to stop my arlo subscription from auto renewing. I was on arlo premium free for 30 days. I decided to return the cameras to purchase the Ultras in black friday instead. So right now I do not have an arlo system.
Online it says to go to subscriptions and select change plan and then select the basic (free) plan. When I do this I do not have the option for the basic free plan.
Any help would be reallky appreciated. Thank you.
One workaround is to remove the credit card number.
You might want to contact support: https://www.arlo.com/en-us/support/contact.aspx
Unfortunatley it does not allow you to remove your card and save. Requires a number to be entered. I'll contact support.
SAME! Will not let me remove CC. There are no options to cancel.
Hi @JCFWTX
The problem has been resolved. And in fact, it was operator error. (or bad design)
When you click on 'subscription' it DOES have a 'CANCEL'. But it is next to a green button that you can select. It is gray letters with no button around it. So it looks like you can not select it because it is gray. You can click on the letters 'CANCEL' and it will take you to another screen to finish the cancelation of the upgraded service.
BTW- I love the products. I just don't have a need for these addons.
animal
Arlo Q Series
detection
e911
notifications
Servicio y Almacenamiento
