How do I turn Smart siren so it goes off if it sees motion?
  • 5 Replies
  • 4050 Views
TSport
How do I turn siren so it goes off if it see motion. As soon as I turn it on it just starts. I want to set it so it only goes off if there is motion.
michaelkenward
Sensei Sensei
Sensei
@TSport wrote:
I have 3 cameras. I can only get one to work at a time with the siren.... is there a way to set up all three running at the same time to be set for the siren.
Add new rules for the cameras that do not sound the alarm.
Just another user
5 REPLIES 5
Create a custom mode with the cameras you need, and then add the siren to sound as the additional rule
OR
when you say turn on the siren sounds, are you hitting the icon or setting the siren on in the current mode ( you prob need to edit the mode )
TSport
I do most see Mode/rules only Mode....When I go into mode it just gives me the option armed (motion and audio detection on) which I have it on... the siren goes on as soon as I turn it to on...not when there is a motion only
Other options are disarmed/schedule/geofencing and Add a Mode
when I go to add a motion cause I thought maybe I could add for the siren to only go off when there is a motion.... it doesn’t give options, just a space for me to type.
TSport
Thanks, figured out how to make rules in mode and got siren working to motion....only thing is now.... I have 3 cameras. I can only get one to work at a time with the siren.... is there a way to set up all three running at the same time to be set for the siren.
michaelkenward
Sensei Sensei
Sensei
Just another user
TSport
Thanks!
