  • 56 Replies
  • 12775 Views
alex_loo
Virtuoso
Virtuoso
This is very weird and already the 3rd consecutive night happening this.
I have this time routine switching to ArmAway every 1130pm, followed by no notification.  Running Perfectly perfect so far.
And then these 3 nights, it still switched to arm away, but then
  • Notification about motion alert of 1 of my 3 cameras
  • Recording with that camera ( and there was no motion at all)
The camera in context happens to be the last camera that is armed up.
Anyone experiencing something similar?
Alex.
56 REPLIES 56
Not here but there have been scattered posts about mode switching causing cameras to record. Of course, motion may have been detected but was too fleeting to capture due to the camera startup time. I've also had recordings apparently caused by a different camera's IR LEDs being detected. Why those LEDs happen to have been turned on isn't necessarily known. It's apparent that overnight cameras seem to activate when checking for updates or similar activity.
alex_loo
Virtuoso
Virtuoso
@jguerdat do you have links to those scattered posts? Thanks.
Alex
No, I don't track such things except in my (feeble) head. Here's one such I found with a search for "mode switch camera records" here:
https://community.arlo.com/t5/Arlo/When-a-mode-activates-all-cameras-record-automatically-with-the/m...
alex_loo
Virtuoso
Virtuoso
thanks.  I had a read of that thread.  Turned out it was NOT an ARLO bug, but mis-configuration with the scheduled routine.
Do you recall any other cases?
Alex
Nope. My search for exactly the same thing turned up different results that had no utility. The posts have been sporadic so there's no easy way to find them.
alex_loo
Virtuoso
Virtuoso
Alex.
so back to my issue .....
I did try something with the 1130pm schedule routine that switches to ArmAway.  Adding "send notification" as the action together with the switch action (my original routine did NOT have the action of sending notification).
And the result?  Still buggy, sending me this WRONG notification, every time the 1130pm routine (correctly) switches to ArmAway.
Sigh.  Anything that can go wrong, ARLO will just get it wrong.
Alex
BrookeN
I have let the development team know the behavior you are seeing. I will update you as soon as possible.
alex_loo
Virtuoso
Virtuoso
thanks @BrookeN .  Are you able to let development team know about the geofencing issue?  This is more important, actually a show stopper to me.
Alex
BrookeN
@alex_loo the development team is already currently investigating the behavior with Geofencing. I will update the community as soon as I have any updates.
alex_loo
Virtuoso
Virtuoso
@BrookeN wrote:
@alex_loothe development team is already currently investigating the behavior with Geofencing. I will update the community as soon as I have any updates.
thanks @BrookeN .  More than happy to provide info on error cases and assist with testing, if that helps.
Alex
alex_loo
Virtuoso
Virtuoso
so this is about the issue as reported by the original post ---- false motion recording+notification every time when my automation routines (correctly) switches to ARM AWAY at scheduled time of 1130pm, but then also incorrectly recording motion + sending notification.
Given your other reply re the geofencing issue, just some reminder regarding above too.
(this is still happening every 1130pm here!)
Alex
BrookeN
Our team is still looking into this behavior, I will update the community as soon as possible.
alex_loo
Virtuoso
Virtuoso
hi @BrookeN ,
Do you have updates regarding this?
Alex
BrookeN
@alex_loo I am checking on this, I will update you later today or tomorrow.,
alex_loo
Virtuoso
Virtuoso
@BrookeN wrote:
@alex_looI am checking on this, I will update you later today or tomorrow.,
thanks.  I notice there were 2 issues mentioned in this conversation:
1. geofencing issue
2. false recording by camera, when it get kick-started arming (correctly) by 1130pm routine.
I was asking about issue #1 (ie geofencing).  It has not improved at all.
Issue #2 on false recording has disappeared recently.  Nothing for ARLO to follow up, from me.
Alex
FWIW, GF has recently been working properly for me. This was with both the 5.7 as well as 5.7.4 Android apps. Whether it remains working, we'll see.
alex_loo
Virtuoso
Virtuoso
1. geofencing issue
Alex
@BrookeN , as mentioned above, I desparately need fixes on "#1 geofencing issues".  I haven't seen and heard any good news yet.
Alex
BrookeN
We are still working on the behavior that is seen with Geofencing. I will update the community as soon as possible.
alex_loo
Virtuoso
Virtuoso
Hi @BrookeN , do you have update on this?
I can provide my app log, if that helps.
Alex
BrookeN
Yes, I will need the app logs sent over as well as screenshots and timestamps on when this occurred. Thank you.
alex_loo
Virtuoso
Virtuoso
My setup here is:
  • 1x Android phone, logging in as main account
  • 1x iPhone, also logging in as main account
Do you need logs from both phones, or which one?
If log from iPhone is needed, please share as to how to extract the log.  (I know the android way, but it does not work on iPhone app)
Alex
BrookeN
@alex_loo are you still seeing this same behavior?
alex_loo
Virtuoso
Virtuoso
@BrookeN wrote:
@alex_looare you still seeing this same behavior?
hi @BrookeN , yes the issues never improve at all.
  1. Just yesterday, my device and wife's device were leaving, but ARLO didn't switch to ARM AWAY and it should have, according to my away routine
  2. While both devices were away and ARLO was ARM AWAY, and then wife's device was back.  ARLO did NOT switch to STANDBY, but it should have, according to my ARRIVE routine.
  3. As the next scenario of number 2 above (ARM AWAY, wife device home already, my device still away), when my device is back, ARLO did NOT switch to STANDBY, but it should have, according to my ARRIVE routine.
Months ago, I submitted data log on similar issues, but have heard nothing.  And again, such basic geofencing has NOT been working, since more than 14 months ago, when I first owned the whole system.
Alex
I'm now on (Android) 6.2.8 with GF working 100% for a while now.
