My vmb4540 hub was connected and working fine with my 3 pieces of 4pro xl cameras. Suddenly yesterday the hub start to blink orange color. I did factory reset but i still cannot connect my cameras to hub. My hub is able to connect and is online. I can connect my cameras to wifi router also but whatever i do i cannot connect cameras to the hub. I tried factory reset of hub and removed from my account and the cameras but it does not help.
Do you see the Arlo wifi network when you search for networks in your phone or PC?
Hi, no i cannot see. How can i set it back?
That suggests that the wifi in the base might have failed.
You can try removing it (and the cameras) from the account, and then resetting the base using a paper clip. Then see if you can find the Arlo network (will have Arlo in the network name, along with other stuff).
Thanks for the answer. If i still cannot see? Is there any more deep reset (like reboot) rather than pressing the reset button for 10 sec?
Not that I know of.
animal
Arlo Q Series
detection
e911
notifications
Servicio y Almacenamiento
