I use Samsung J7 Core with android v.8.1.0
After I update arlo smart to v.2.6.3_23000 , arlo smart alway close qhen loging in.
I try reinstall application on play store but problem don't sloved.
Many existing threads on this. It only happens on some devices. I have 3 and it only happens on 1. Open a case with support here to add pressure.
You can also try a different device and/or use a browser.
Did you contact support as suggested?
By the way , after I install lastes version (27/11/2018) , the problem disappear.
I think developer fix bug in application.
Update lastes version can solve tyis problem.
Thank all.
Glad that the update fixed things. SHould you need to contact support, just use the Contact SUpport link at the bottom here and again on the new page. The 3rd page has the contact options:
animal
Arlo Q Series
detection
e911
notifications
Servicio y Almacenamiento
