Just had a popup when I launched the arlo app. It was an offer for 99 cents per cam smart plan. And it poofed! Anybody else seen it or tell me how I can get the offer back?
Yes! I just had it pop up on my app this morning. I actually clicked it to process the deal, but it still showed $2.99 price per camera at check out. Is there a promo code or something we can use?
And as luck would have it...the offer just popped back up! very samll print at top of offer that discount will be applied at checkout. I put it on 2 cameras and it gave me the discount
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Call them and they told me it was a computer mistake even though there processed the payment.
arlsmtussw99cq20
I got popup for 99 cent per camera today to on Android, when tried to accept it went to free month then asked to pick from 2.99 plans, so canceled process
It says in green font "discount applied at checkout" on that page. 2.99 up front, then discounted at checkout.
This code worked for me. But looks like only one month. But this gives me time to decide what smart plan, how many cameras etc Thank you
Like you said only good for 1 month
I take it 😀 not paying $6
$1 should be enough
@Jjfresh wrote:
Big scan going on here someone should sue Arlo for false advertisement they say 99 cent per camera and when u go to check out hahh not at all what they are advertising
What did they charge you at checkout when selecting activate Arlo Smart? Did you select a single cam plan as it says.
Yes I just saw the same offer on my phone and I accepted it but then nothing happened afterward !!
animal
Arlo Q Series
detection
e911
notifications
Servicio y Almacenamiento
