Arlo Base online but cannot connect
Hi,
my Arlo base and camera were just working fine. Suddenly the app says that the station is offline.
I tried to rest the system and the station shows the internet LED green but the app still sees is offline.
What can I do?
e911
test the system on a PC with a browser (https://arlo.netgear.com/) to see if it's the app or the system
Thanks for the quick reply.
Yes, it's the same on the app and on the browser of the PC.
The next easy thing to do is a power button reboot...off then on, wait about 2-3 mins to come back online
giuseppepesce,
What are the status LEDs displaying on the base station after you rebooted it?
First 3 LEDs are fixed green: power, internet and cameras..
giuseppepesce,
Have you checked over WIFI or cellular data?
I checked and open the ports so now everything works well.
Thanks for the help and support.
giuseppepesce,
You are welcome!
animal
Arlo Q Series
detection
e911
notifications
Servicio y Almacenamiento
