  • 9 Replies
  • 7589 Views
giuseppepesce
Hi,
my Arlo base and camera were just working fine. Suddenly the app says that the station is offline.
I tried to rest the system and the station shows the internet LED green but the app still sees is offline.
What can I do?
  • e911
9 REPLIES 9
test the system on a PC with a browser  (https://arlo.netgear.com/) to see if it's the app or the system
giuseppepesce
Thanks for the quick reply.
Yes, it's the same on the app and on the browser of the PC.
The next easy thing to do is a power button reboot...off then on, wait about 2-3 mins to come back online
giuseppepesce
i did it and unfortunately nothing changed.
ShayneS
giuseppepesce,
What are the status LEDs displaying on the base station after you rebooted it?
giuseppepesce
Hi,
First 3 LEDs are fixed green: power, internet and cameras..
ShayneS
giuseppepesce,
Have you checked over WIFI or cellular data?
giuseppepesce
My internet provider updated the router firmware without letting me know and therefore the porta were blocked.
I checked and open the ports so now everything works well.
Thanks for the help and support.
ShayneS
giuseppepesce,
You are welcome!
