  • 5 Replies
  • 2087 Views
8312622554
I have 3 arlo ligh, one of them I installed in the living room, how do i just deatcivate this one
5 REPLIES 5
Just like the cameras, create a custom mode with only the two wanted cameras in it
Thank you for your reply, did you actually try yourself or you just think it should be
I just Test by creating mode as you said, it seems not work as you said
Tom's right. A mode without a rule for a camera or light means that device is disarmed. Or isn't that what you're after?
8312622554
I have 3 Arlo light, two installed in outdoor and one In indoor, I want to deactivate the one in indoor when I am at home
You need two modes - one with rules for all lights (Armed or custom) and one without a rule that one light. Read the FAQs here on creating nd modifying modes and rules. You can then use the schedule or geofencing to automate the process.
  • 5 Replies
  • 2088 Views
