  • 11 Replies
  • 8771 Views
  • 3 Likes
  • 6 In Conversation
EdwardNNC
I cannot find the 3 pack security light set on the costco website.
Is it still available for $149?
11 REPLIES 11
EdwardNNC
Another question...
Is the Costco version different tab the standard set?
Hardware-/software-wise, it should be identical. It's what's in the package that makes it unique (exact mix of devices, mounts, etc.).
BEA_ICU
Yes, as of today (2/6/2019), it's $99.
EdwardNNC
Thank you!
I only see that it has an extra battery.
Everything else looks good.
I was wondering if they were new or refurbs mostly.
EdwardNNC
Do you have a link to the light package?
I cannot find it on their site.
BEA_ICU
Just got mine in store (MD) yesterday for $99.
RichLevow
Picked up one yesterday at Costco in Westbury, NY for $99.00.  Apparently they are not selling well according to one of their employees I spoke with.  Still worth it for the batteries and mounts.
EdwardNNC
I got two packs.  Now to figure out how to use it in the app.
JessicaP
Hi @EdwardNNC,
If you need help on how to set up the Arlo Security Light system, you can read this article: How do I set up my Arlo Security Light system?
EdwardNNC
Thank you Jessica.
I got the 1st camera working again.
It worked when I first added it, then stopped for some reason.
I added a 2nd camera and it worked with no issues.
I went through the settings of the 1st again ( a couple of times ) and it started working again.
I am not sure what happened, but I am going to assume that I did not hit save when I put the settings back the first time I changed them... and it was still going off of disabled for some reason.  I could cut the light on manually, but I could not get it to alert me to motion.
It seems fine now.
mde8965
Picked up a pack still at $99 at the Costco in Clearwater FL. They had at least 15 or 20 of them on display. Wish I saw this thread before I bought my first pack 2 weeks ago for $150 on Amazon.
  • 11 Replies
  • 8772 Views
  • 3 Likes
  • 6 In Conversation
