Arlo Security Light System: Do I need additional light to sync to Base Station?
  • 6 Replies
  • 4714 Views
  • 6 In Conversation
TheWatcher24
I have a 1st Gen arlo wire free base station with 3 cameras , do I need anything additional to sync an arlo light to my base station ? If I just buy an arlo light alone , can I use my base station?
6 REPLIES 6
steve_t
Master Master
The Arlo Security Light requires the Security Light Bridge. The bridge connects to the light via Bluetooth. The bridge connects to your home wifi. Only through the cloud do the cameras and lights communicate. Don't ask me why they did it this way
michaelkenward
Sensei Sensei
Sensei
Something about the range of low power bluetooth?
By binding several lights on to one bridge, it is also a way of cutting down the number of wifi clients that a router has to handle.
Over on the routers community there is a growing stream of messages about the explosion in IoT stuff running up against the limits when it comes to the number of wifi clients that a router can handle. Who knows if this is related to the hubs?
But it would be nice to know what the engineers behind these things had in mind.
Just another user
The range is a theoretical 160 feet/50 meters.
https://www.digikey.com/en/articles/techzone/2011/dec/bluetooth-goes-ultra-low-power
My one light is a good 75 ft from the bridge and works fine...  so it could possibly go a bit more,
there is a signal indicator.
TheWatcher24
So the "bridge" is something additional to the base station that my cameras connect to? Thanks
JessicaP
Hey @TheWater24,
You're correct! In order to use your Arlo Security Light, you will need to sync with the Security Light Bridge (not the Base Station) as steve_t mentions.
  • 6 Replies
  • 4715 Views
  • 6 In Conversation
