Arlo Security Lights change color when light is armed?
  • 1 Reply
  • 1750 Views
jtroxler
Can you change the color of the light for when the light is armed? I go into each light and change the color in the setup. When the system is armed and the lights turn on with motion, the light comes on as the standard white light. I would like to have the light come on when activated with motion to the color I have set.
I just tested this on the web..( are u using an app ? )
In settings, change color, toggle a different color and it auto saves ( take a sec )... works as should
  • 1 Reply
  • 1751 Views
