Arlo Security Light Firmware Update
  • 5 Replies
  • 4691 Views
tkrpata
Just purchased an Arlo Security Light and after installing and firmware update I realized I still had the old firmware 3.2.25 vice the latest 3.2.45 (with the dusk to dawn option).  I tried to reinstall the light but the same thing happened when I called Arlo they didn't understand and could not help. Is there a way to manually update the firmware or do I need to return the product for a new one? Only got this one a week ago
tkrpata
Looks like the firmware updated last night 3.2.51 and Dusk to Dawn Sensor working
5 REPLIES 5
Try unplugging the base and plug back in. Also, try reinserting the battery from the light. Is the bridge up to date as well as the app?  If still no good, you may need to remove the light from Settings, My Devices and resync it.
tkrpata
Tried all that and still shows the last firmware update and not the latest, I even reset to factory settings
What's the firmware on the bridge? Mine is 2.0.1.0_233_142. Also, my light firmware is 3.2.51.
Sarath_Inampudi
Arlo Employee
Arlo Employee
tkrpata
  • 5 Replies
  • 4692 Views
