  • 7 Replies
  • 2376 Views
JayVon
Hello All,
I've recently purchased a brand new Arlo light Bridge with 3 smart lights through marketplace but to my avail and countless hours I have not been able to connect.
I researched multiple posts here and followed all the steps from factory resetting, VPN, and changing wifi bands.
Nothing works and am at a loss.
I can provide SN and all information if needed.
7 REPLIES 7
ShayneS
Hi @JayVon
What is the error messaging received when trying to install the devices?
Did the previous owner remove the devices from their Account first?
JayVon
Hello @ShayneS ,
Arlo lights and bridge were sealed and we're not tied to an account prior to purchase.
I noticed that the light bridge would turn off after trying to pair with my wifi ( set at 2.4 channel ) resulting in an error where it could not connect. Basically a long the lines of " Trouble connecting to with WiFi. Try again "
I tried on Android and iOS and still no luck. While other devices connected and are functioning properly. Not sure if I have a faulty equipment.
I can provide S/N and codes if it can assist in the process.
ShayneS
Can you provide the model number(s) and S/N? I will have the team look in to this.
JayVon
Hello @ShayneS
Model: ABB1000
S/N: 5631855X19976
Thank you for your assistance.
ShayneS
Thanks, can you try that factory reset method a few times to see if we can get the device to connect.
https://kb.arlo.com/000061857/How-do-I-perform-a-factory-reset-on-my-Arlo-Bridge
katty867
Hello,
Thanks for this info. MyCentura
Best Regards
katty867
MarioWatch
Hello,
I have the same issue. Lightbridge is not onboarding for some reason. It always worked.
So I try to onboard it … App is saying “Connecting to xxxx” … but it stays stuck there and does not go further.
I also tried to factory reset by holding the button for 40s. Still the same results …
Anything that worked for you?
Best regards
Mario
  • 7 Replies
  • 2377 Views
