I purchased arlo 5S cameras to replace eol pro and pro2 cameras. I had no problems with video or connectivity with the old cameras, but the new ones I can't get the activity zone setup because you can view the video. I get alarms and video with the alarms for whatever the default activity zone is, but I can't see live video or be able to get video to setup the activity zone.
same issue for me.
Surely there will be a new update for the app because this current version has glitches imo.
kriddle_277,
When you try to live stream the camera, are you getting any error messages? What does the signal strength icon show for the camera?
No error messages. Signal is full strength. It is only on the Feed tab that the picture cannot return to the main screen. Changing the iPad’s orientation has no effect. There is no back-up or return arrow.
Everything else works perfectly. Thanks so much.
Activity zones showed up yesterday, so maybe it takes time for the system to register everything. Only issue now is the Feed window, when opened, doesn’t return to the main screen - on an ipad.
I have full bars, sometimes I get an error and other times it spins until it times out. I'm using the computer with Window 11 and Chrome. I don't have problems with the other 2 new cameras.
Arlo 4.1 App release notes
Arlo app
arlo not working
Arlo Pro 5
Arlo Pro 5S 2K
Arlo Secure 4.0
Automation
cameras
custom modes
Friend
Grant Access
my.arlo.com
notifications
Pro 5s
Security System App
Temporary disable
Vacation override
