  • 7 Replies
  • 684 Views
dbharness
how do i change the time on the hub? Version VMB4000r3. firmware 1.25.1.0_4598_1f1c874
7 REPLIES 7
It's now in Settings, Home, Time Zone.
dbharness
cant repost pic see next post
dbharness
That does not exist on my home screen. See image above.
dbharness
Do you use Library to view recordings (old interface) or Feed (new interface)? For the former, try this (yes, it says camera but try the base):
https://kb.arlo.com/000062607/How-do-I-set-the-time-zone-for-my-Arlo-camera
I see your screenshot now so you're using Feed. You're in the wrong place. I simply click on Settings, Home and Time Zone is right there.
@dbharness:  If you entered an address for the location, then you cannot change the timezone.  It's locked to the timezone used at that address.
